[GRASSLIST:10598] Re: GRASS 6.1cvs gis.m error
Ing.Peter Misovic
peter.misovic at gmail.com
Sun Feb 26 16:58:44 EST 2006
Thank you Michael for you information.
Peter
On 2/26/06, Michael Barton <michael.barton at asu.edu> wrote:
> Peter,
> It may well be the case that your v.what is newer than the one in the
> package from my website. Now that it is in the CVS, you should use that one
> instead of the one in the package on my website. I will take that one out so
> as not to confuse anyone.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: "Ing.Peter Misovic" <peter.misovic at gmail.com>
> > Date: Sun, 26 Feb 2006 21:37:26 +0100
> > To: GRASSLIST <GRASSLIST at baylor.edu>
> > Cc: Michael Barton <michael.barton at asu.edu>, Glynn Clements
> > <glynn at gclements.plus.com>
> > Subject: Re: [GRASSLIST:10572] GRASS 6.1cvs gis.m error
> > Things are going to be complicated. As I wrote, I started gis.m from
> > directory with right permissions and it works fine. I liked to try
> > last gis.m from your site Michael. So I copied sources of v.what into
> > vector folder of Grass and started to configure and make Grass again
> > (if I understand it, I have to do that way) - to make newer version od
> > v.what. But :
> > Generating HTML manual pages index (help system)...
> > Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
> > Following modules are missing the 'description.html' file in src code:
> > g.pnmcomp
> > GRASS GIS compilation log
> > Started compilation: Sun Feb 26 21:10:15 CET 2006
> > Errors in:
> /home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/raster/
> > r.le/r.le.setup
> /home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/vector/
> > v.what
> > Finished compilation: Sun Feb 26 21:27:04 CET 2006
> > (In case of errors please change into the directory with error and run
> 'make')
> > I tried to make it directly in v.what folder but :
> > [misovic at thailon v.what]$ make
> > gcc
> -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_20/dist.
> > i686-pc-linux-gnu/include
> > -O3 -mcpu=pentium4 -Wall -Wall -Wconversion -Wno-implicit-int
> > -I/usr/local/include -DPACKAGE=\""grassmods"\"
> > -o OBJ.i686-pc-linux-gnu/main.o -c main.c
> > `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
> > main.c:24:21: glocale.h: No such file or directory
> > main.c:25:17: gis.h: No such file or directory
> > main.c:27:18: Vect.h: No such file or directory
> > main.c:28:20: raster.h: No such file or directory
> > main.c:30:18: dbmi.h: No such file or directory
> > main.c:32:20: config.h: No such file or directory
> > main.c: In function `main':
> > main.c:40: error: storage size of 'window' isn't known
> > Please, would I stay with old v.what from
> > grass-6.1.cvs_src_snapshot_2006_02_20 in combination with news gis.m
> > and gm folder or is better to make it with untouched original source
> > of CVS Grass.
> > Thank you,
> > if it is just because of development I understand and I shall wait.
> > Peter
> > On 2/26/06, Ing.Peter Misovic <peter.misovic at gmail.com> wrote:
> >> Yes, I understand the concept. It works fine now. I've started Grass
> >> from folder with limited write permissions.
> >> I have question in regard of this issue. Is it problem to find out in
> >> script (code) from system WHO is starting script ? If it is not, the
> >> script could create temp (etc.) files directly into home directory of
> >> user who has started this script. Even if the sctipt is not starting
> >> from user's home directory.
> >> Peter
> >> On 2/26/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> >>> Ing.Peter Misovic wrote:
> >>>> I'd like to ask you for help with gis.m Grass manager. Manager is not
> >>>> starting properly 'cause it is crashing with following error :
> >>>> ERROR: PNG: couldn't open output file dispmon_1.ppm
> >>> The PNG driver is trying to save its files in the current directory.
> >>> If you don't have write permission on that directory, it will fail.
> >>> Similarly, if the file already exists but you don't have write
> >>> permission on it, it will fail.
> >>> ISTR that later versions of gis.m tell the PNG driver to put the files
> >>> in a temporary directory.
> >>> Either cd to a directory for which you have write permission, or
> >>> update to a more recent version of gis.m. In any event, you should do
> >>> the latter sooner rather than later, as gis.m is under active
> >>> development.
