[GRASSLIST:10611] Re: GRASS 6.1cvs gis.m error - raster/r.le/r.le.setup
    Glynn Clements
    glynn at gclements.plus.com
    Mon Feb 27 12:06:30 EST 2006
Ing.Peter Misovic wrote:
> Markus, this is error you've asked (occures after make command) in
> raster/r.le/ folder.
> [misovic at thailon r.le.setup]$ make
> Makefile:16: warning: overriding commands for target `clean'
> ../../../include/Make/Rules.make:34: warning: ignoring old commands
> for target `clean'
> gcc -I/home/misovic/download/gis/grass/grass-6.1.cvs_src_snapshot_2006_02_25/dist.i686-pc-linux-gnu/include
>  -O3 -mcpu=pentium4 -Wall  -Wall -Wconversion -Wno-implicit-int
> -I/usr/local/include     -DPACKAGE=\""grassmods"\"
>         -o OBJ.i686-pc-linux-gnu/sample.o -c sample.c
> `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
[snip]
> sample.c:994: internal compiler error: in convert_move, at expr.c:566
> Please submit a full bug report,
> with preprocessed source if appropriate.
> See <URL:https://qa.mandrakesoft.com/> for instructions.
It's an internal compiler error (i.e. an error in the compiler, not
the file it's trying to compile). As it says, report it to whoever
built gcc (i.e. Mandrake). I doubt that there is anything that we can
do about it.
