[GRASSLIST:10624] r.mapcalc problem
Silvia Franceschi
silvia.franceschi at ing.unitn.it
Tue Feb 28 04:06:01 EST 2006
Hi all,
I am trying to do a mapcalc between two maps, the first one is a dsm (digital
surface model) and the second is a dtm (digital terrain model).
The dsm is defined only where there are features on the surface and the dtm is
defined all over the region.
I would like to fill the holes in the dsm map with the correspondets values of
the dtm using a mapcalc:
r.mpacalc "new_map=if(dsm,dsm,dtm)"
Using this command I obtain a new map equal to the dsm map.
If I use these instead:
r.mpacalc "new_map=if(dsm!=null(),dsm,dtm)"
r.mpacalc "new_map=if(dsm==null(),dtm,dsm)"
I obtain two maps with all values nan.
Do someone knows the right way to do this mapcalc?
Thanks in advance...
Silvia
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
Via Siemens, 19
39100 Bolzano
www.hydrologis.com
Silvia Franceschi
Environmental Engineer
tel: +390471068066
mobile: +393384501332
email: silvia.franceschi at hydrologis.com
