[GRASSLIST:9705] Re: switching to postgres
Kirk R. Wythers
kwythers at umn.edu
Tue Jan 3 13:11:35 EST 2006
Leonardo,
This issue disappeared for me when I updated GRASS from CVS (as
recommended by Radim).
Kirk
On Jan 3, 2006, at 9:21 AM, Leonardo Lami wrote:
> Hi all,
> I see that this problem is common to many commands.
> We see this problem when we change Postgres 8.0 in Postgre 8.1
> In the new version the table are created without oid like you can
> read above:
> (default_with_oids (boolean)
> This controls whether CREATE TABLE and CREATE TABLE AS include an
> OID column
> in newly-created tables, if neither WITH OIDS nor WITHOUT OIDS is
> specified.
> It also determines whether OIDs will be included in tables created
> by SELECT
> INTO. In PostgreSQL 8.1 default_with_oids is disabled by default;
> in prior
> versions of PostgreSQL, it was on by default.
> The use of OIDs in user tables is considered deprecated, so most
> installations should leave this variable disabled. Applications
> that require
> OIDs for a particular table should specify WITH OIDS when creating
> the table.
> This variable can be enabled for compatibility with old
> applications that do
> not follow this behavior.)
> If you want create a table with oid cloumn you must use the follow
> sql:
> 'create table tablename with oids';
> or you can change the file:
> /etc/postgresql/8.1/main/postgresql.conf
> setting:
> default_with_oids = true
> but, probably, the rigth way is debug GRASS modules
> Best regards
> Leonardo
> Alle 18:54, giovedì 15 dicembre 2005, hai scritto:
>>> 6. use db.describe to check out the vector in GRASS
>>> GRASS 6.1.cvs (spearfish60):~ > db.describe table=spearfish_soils
>>> driver=pg database=spearfish_soils
>>> DBMI-Postgres driver error:
>>> select * from spearfish_soils where oid < 0
>>> ERROR: column "oid" does not exist
>>> What is oid? I can see from the columns that postgres printed out
>>> that I
>>> have only columns cat and label, no oid. Is this something that
>>> should
>>> have copied and did not?
>> This is bug. By default postgres is using OID (hidden) column
>> for each table. But it is possible to configure postgres to create
>> tables
>> without that column. My fault, it was stupid to use oid.
>> Fixed in CVS.
>> Radim
