[GRASSLIST:9716] Re: drop column?
Markus Neteler
neteler at itc.it
Wed Jan 4 12:00:51 EST 2006
M S wrote:
>is there a drop column command? i didnt see one in the man pages, and
>when i tried the "ALTER TABLE table DROP COLUMN column_name" |
>db.execute it didnt like that command but i was able to add
>columns..
It depends on the DB driver. I assume that you use DBF? Then it doesn't
work since DBF is very limited. For all other drivers it should (untested).
Markus
