[GRASSLIST:9720] RE: which linux distribution?
Aaron Racicot aaronr at ecotrust.org
Wed Jan 4 13:06:00 EST 2006
Robert,
I use Fedora on all of my server boxes and have had great success with
GRASS/MAPSERVER/QGIS/POSTGIS etc.  I even just recently installed Fedora
Core 4 on a new Dell 9300 laptop and installation has been going very
smoothly.  If you decide to go with Fedora let me know, I can probably
help you through some of the installation if you have problems.
Aaron
| Aaron Racicot  | aaronr at ecotrust.org   |
| GIS Programmer | 503.467.0759          |
| e c o t r u s t                        |
| Jean Vollum Natural Capital Center     |
| 721 NW Ninth Avenue                    |
| Suite 200                              |
| Portland, OR 97209                     |
| www.ecotrust.org                       |
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Robert Kuszinger
Sent: Wednesday, January 04, 2006 8:43 AM
To: GRASSLIST at baylor.edu
Subject: [GRASSLIST:9715] which linux distribution?
Hi all!
I'm planning to put a second HDD into my notebook for using grass as it
seems to be
much more up-to-date and better on Linux than under Cygwin (which is
good for many things, really, and good to have, but I better use Linux
for production)
My question is, which Linux distribution to choose?
I have Debian but that is versions back for stability (i do understand)
and
if I switch to the unstable tree in sources.list it starts to create
strange links
(if I install a library, it uninstalls another and changes version and I
loose an important package,
etc)
What do you use for compiling/development, for example? Which one is the
best.
My main target application is GRASS, so this is the main point.
thanks
Robert
