[GRASSLIST:9723] Re: drop column?
Maciek Sieczka werchowyna at epf.pl
Wed Jan 4 16:41:35 EST 2006
On śro, 2006-01-04 at 18:00 +0100, Markus Neteler wrote:
> M S wrote:
> >is there a drop column command? i didnt see one in the man pages, and
> >when i tried the    "ALTER TABLE table DROP COLUMN column_name" |
> >db.execute   it didnt like that command but i was able to add
> >columns..
> It depends on the DB driver. I assume that you use DBF? Then it doesn't
> work since DBF is very limited. For all other drivers it should (untested).
not for sqlite too, a great shame...
http://www.sqlite.org/omitted.html
Maciek
Szykuje się długa i mroźna zima? Nie pękaj!
Hurtownia prezerwatyw  http://www.jak-pol.com.pl/
