[GRASSLIST:9761] Re: vector corruption? after qgis session crash
Radim Blazek
radim.blazek at gmail.com
Sat Jan 7 07:05:19 EST 2006
On 1/6/06, Dylan Beaudette <dylan.beaudette at gmail.com> wrote:
> On Thursday 05 January 2006 09:35 pm, Dylan Beaudette wrote:
> > Hi,
> > After a QGIS editing session crash, the vector that i was editing now has a
> > small problem. when working with this vector i get the following warning:
> > d.vect pedons
> > D1/1: Info->size = 6481, Info->mtime = 1136524613
> > D1/1: coor size in head = 6452, real coor file size= 6481
> > WARNING: coor files of vector 'pedons at waypts' is larger than it should be
> > (29 bytes excess).
> > this file seems to work, but the warning is annoying. I have tried v.build,
> > however this does not fix the problem. is there any quick way to fix this,
> > or am i going to have to export the vector to text, and re-import it ?
> > thanks in advance,
> Thanks for the tips. Opening the vector in v.digit, adding a new point, and
> quitting seemed to fix the problem.
> Yay!
Open and close should be enough.
Radim
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
