[GRASSLIST:9762] Re: v.db.connect and schema
Radim Blazek radim.blazek at gmail.com
Sat Jan 7 07:03:32 EST 2006
On 1/5/06, Martin Landa <landa.martin at gmail.com> wrote:
> Hi all,
> is it possible to connect a table to a map by v.db.connect with
> schema? There is no schema parameter and table name [schema.table] is
> not valid, see
> v.db.connect map=cr table=cr.cr -o
> Illegal table map name <cr.cr>. Character <.> not allowed.
table=schema.table should be valid in my opinion, if a check for
dot in name was introduced somehow it should be removed I think.
I am not sure if schema parameter is better in this case.
IIRC the module checks if the table exists anyway.
Radim
> Thanks, best regards, Martin
