[GRASSLIST:9804] Fwd: Hindi support in GRASS 6.1 - was Re: [GRASS5] Fwd: Indic support in GRASS GIS with Indix2
Swapnil Hajare dreamil at gmail.com
Thu Jan 12 06:02:55 EST 2006
---------- Forwarded message ----------
Date: Jan 5, 2006 3:02 PM
Subject: Re: Hindi support in GRASS 6.1 - was Re: [GRASS5] Fwd: Indic
To: Sajith VK <sajithvk at gmail.com>, grass developers list <
grass5 at grass.itc.it>, GRASS user list <grasslist at baylor.edu>
  sorry for such a late response.
  I downloaded the CVS version of GRASS GIS and compiled it on my debian
sarge machine. I then used the commands given by you to create a sample
vector and displayed it on monitor. For the example that you have in your
snapshot, it works fine. But then I realised that you have displayed a
string in devanagari/hindi which does not require any processing on font
side. i.e. the text is displayed just similar to english text
 using juxtapositioning of glyphs. So I tried with some conjunct text which
requires some positioning/replacement rules to be used from the opentype
font, it couldnot display properly. See the snapshot for details (snapshot
uploaded on http://203.199.16.202/grass_cvs_comparison.png ). The left
monitor show the GRASS CVS version as downloaded on 2006-01-05 and compiled
as-it-is. The right monitor shows output of d.tect.freetype compiled with
Indix2 libraries. The right monitor show properly rendered text while the
left monitor show text in form of  juxtapositioned glyphs. I knew that
because of freetype library GRASS will be able to use opentype fonts but I
also knew that it doesn't have any rendering engine like pango/qt/indix2 to
render complex text in indic scripts correctly.
We had tried this same thing in past without any rendering engine and
failed. That is why I had filed this bug (
http://intevation.de/rt/webrt?serial_num=3189 ). I must apologise for not
following it up properly.
regards
On 12/22/05, Markus Neteler <neteler at itc.it> wrote:
> Hi again,
> an update for support of Indian languages:
> - we now have messages files in Hindi available (still to be
>   translated)
> - we can out-of-the-box generate Hindi (or other) scripts
>   in the GRASS monitor using TTF fonts, see screenshot at
>   http://grass.itc.it/devel/i18n.php
>   -> example for Hindi
>      http://grass.itc.it/images/grass61_hindi_hi.jpg
> Note that this is a proof of concept example in Spearfish,
> done with:
> #extraction of phrase in Hindi:
> head -37 locale/po/grassmods_hi.po | tail -1 > /tmp/hindi
> echo "599505|4921010|`cat /tmp/hindi | cut -d'"' -f2 `" | v.in.asciiout=hindi
> d.rast elevation.dem
> v.db.select hindi
> d.vect hindi icon=basic/circle
> d.font.freetype font=/usr/share/fonts/hi/lohit_hi.ttf
> d.vect hindi disp=attr attr=str_1 lsize=40 lcol=blue
> Works :-)
> Cheers
> Markus
> On Tue, Dec 20, 2005 at 10:38:44PM +0100, Markus Neteler wrote:
> > Hi,
> > I have added Hindi support to GRASS by adding two .po files.
> > After installing
> >  kde-i18n-hi-3.4.2-10mdk
> >  locales-hi-2.3.5-1mdk
> > on my Mandriva box, I can even see the characters. With
> > d.font.freetype it should be possible to print them on the monitor
> > such as for Japanese and Chinese. Screenshots asap...
> > I fetched the KDE Hindi file and autotranslated the GRASS
> > messages, some hundred fuzzy translations resulted. Since
> > my Hindi is a bit rusty, I would leave the verification to
> > native speakers.
> > You can grab the wto hindi files from here
> >  -> Download current .po files from CVS
> >     -> grasslibs_hi.po
> >     -> grassmods_hi.po
> > Please send updates to these files regularly, in order to
> > stay in sync.
> > If needed, I can add other languages are well.
> > Cheers
> >  Markus
> > On Mon, Dec 19, 2005 at 07:43:53AM +0100, Swapnil Hajare wrote:
> > > hi,
> > >  greetings.
> > >   not sure if the new GTK gui will solve our problem. Does the new GUI
> means
> > > GRASS monitors will use pango for rendering? I guess they will use the
> same
> > > monitor. And by the time they come up with new GUI, should we wait for
> them
> > > to finish and then start our localised GIS work ? My feeling is this
> should
> > > be seen as a patch for indic support (similar to d.text.freetype used
> for
> > > CJK). correct me if I am wrong.
> > >   I am also not sure  how many indic scripts are supported well by
> Pango/QT
> > > and what is the quality of rendering for all these scripts. If this
> solution
> > > can provide a better rendering solution, it has every right to be
> accepted
> > > as a good alternative to Pango/Qt.
> > > bye
> > > On 12/19/05, Sajith VK <sajithvk at gmail.com> wrote:
> > > > Hello all,
> > > > Sorry for a much belated response.
> > > > Indian Language support for GRASS (For GUI and
> > > > in the map lables) will be highly benificiary.
> > > > A discussion on a better GUI for GRASS is already
> > > > going on. I think it may end up with using GTK or
> > > > QT as toolkit. Both GTK and QT has indian language
> > > > support.
> > > > So this work may become irrelevent, according to the
> > > > future plans of the GUI team. So we may need to switch
> > > > to pango/Qt
> > > > On 12/8/05, Swapnil Hajare <dreamil at gmail.com > wrote:
> > > > > HI all,
> > > > >    my first post. I hope I am posting this is right list.
> > > > >    this is for your comments. If it sounds ok, can some 2-3MB code
> of
> > > > Indix2
> > > > > (indic Shaping Engine) be included in grass code to claim
> something like
> > > > > "GRASS GIS supports 11 Indian Scripts" ?
> > > > Change the rules, or the rules will change you
> > > >      ---------Kumaranasan
> > > Swapnil Hajare
> > Markus Neteler     <neteler itc it>       http://mpa.itc.it
> > ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> > MPBA - Predictive Models for Biol. & Environ. Data Analysis
> > Via Sommarive, 18        -       38050 Povo (Trento), Italy
Swapnil Hajare
Swapnil Hajare
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060112/9f12e8fb/attachment.html
