[GRASSLIST:9844] Re: r.mapcalc causing segmentation violation
Ralf Gerlich
ralf.gerlich at bsse.biz
Sun Jan 15 17:12:51 EST 2006
Hi again,
I have dug a little deeper and realised that it's not the NULL_ROWS, but
the fd that is wrong.
> #1 0xb7f5cd7d in get_null_value_row (fd=0, flags=0x80851f0 "\001\001\001",
> row=1, with_mask=1) at get_row.c:1021
> #2 0xb7f5d35a in get_map_row (fd=0, rast=0x805f360, row=1, data_type=1,
> null_is_zero=0, with_mask=1) at get_row.c:1067
> #3 0x08055b9d in read_row (fd=0, buf=0x805f360 "", row=1, dummy=0)
> at map.c:227
All these have fd=0, which seems odd, as the fd in the source map
structure is originally !=0.
Digging further I found that this happened in column_shift due to
missing breaks in the col<0 part. Adding the breaks fixed the crash.
I have attached the very small patch.
Best regards,
Ralf Gerlich
? raster/r.mapcalc/OBJ.i486-pc-linux-gnu
? raster/r.mapcalc/lex.yy.c
? raster/r.mapcalc/y.tab.c
? raster/r.mapcalc/y.tab.h
Index: raster/r.mapcalc/column_shift.c
RCS file: /home/grass/grassrepository/grass6/raster/r.mapcalc/column_shift.c,v
retrieving revision 2.1
diff -u -r2.1 column_shift.c
--- raster/r.mapcalc/column_shift.c 2 Jan 2006 22:23:32 -0000 2.1
+++ raster/r.mapcalc/column_shift.c 15 Jan 2006 21:52:22 -0000
@@ -69,6 +69,7 @@
for (; i >= 0; i--)
SET_NULL_C(&ibuf[i]);
+ break;
case FCELL_TYPE:
for (i = columns - 1; i >= col; i--) {
@@ -80,6 +81,7 @@
for (; i >= 0; i--)
SET_NULL_F(&fbuf[i]);
+ break;
case DCELL_TYPE:
@@ -91,6 +93,8 @@
for (; i >= 0; i--)
SET_NULL_D(&dbuf[i]);
+ break;
