[GRASSLIST:9858] Re: GeoTiffs shifted by 360 degrees after processing in GRASS
Markus Neteler
neteler at itc.it
Mon Jan 16 10:53:27 EST 2006
On Mon, Jan 16, 2006 at 04:44:57PM +0100, Gross, Dorit (SDRN) wrote:
> Dear all,
> I have a set of GeoTiffs that I import into GRASS to do some processing and
> export them afterwards as GeoTiffs again. The problem now is that GRASS
> exports the images shifted by 360 degrees to the east.
> Corner Coordinates (before the import into GRASS):
> Upper Left (-180.0044643, 75.0044643) (180d 0'16.07"W, 75d 0'16.07"N)
> Lower Left (-180.0044643, -56.0044643) (180d 0'16.07"W, 56d 0'16.07"S)
> Upper Right ( 179.9955353, 75.0044643) (179d59'43.93"E, 75d 0'16.07"N)
> Lower Right ( 179.9955353, -56.0044643) (179d59'43.93"E, 56d 0'16.07"S)
> Center ( -0.0044645, 9.5000000) ( 0d 0'16.07"W, 9d30'0.00"N)
> Corner Coordinates (after the export from GRASS):
> Upper Left ( 179.9955357, 75.0044643) (179d59'43.93"E, 75d 0'16.07"N)
> Lower Left ( 179.9955357, -56.0044643) (179d59'43.93"E, 56d 0'16.07"S)
> Upper Right ( 539.996, 75.004) (539d59'43.93"E, 75d 0'16.07"N)
> Lower Right ( 539.996, -56.004) (539d59'43.93"E, 56d 0'16.07"S)
> Center ( 359.996, 9.500) (359d59'43.93"E, 9d30'0.00"N)
> Has someone of you faced a similar problem? How do I receive a proper
> georeference when exporting from GRASS?
> The input GeoTiffs are a set of converted Spot-Veg HDF files using GDAL.
Did you try to use the dedicated script i.in.spotvgt:
http://grass.itc.it/grass61/manuals/html61_user/i.in.spotvgt.html
Maybe this solves the problem of the global wrap-around.
Please let us know.
Markus
> The -180.0044... degrees for the upper left X seems a bit odd, but GDAL imports
> the Spot-Veg properly with these coordinates. I checked the images in Erdas
> and they are correct. I also checked the corner coordinates of the imported
> file insight GRASS and also here the coordinates are correct. So apparently
> the shift occurs during the export from GRASS into GeoTiff. At the moment I
> solve the problem by reassigning the georeference to the GeoTiff after the
> export from GRASS, but I would be more happy with properly exported images
> right away.
> Can someone help please?
> Thank you,
> Dorit
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
