[GRASSLIST:9866] Re: r.cost and distance to nearest feature
Māris Nartišs maris.nartiss at gmail.com
Tue Jan 17 03:10:52 EST 2006
1) submit this as wish list item at
http://grass.itc.it/bugtracking/bugreport.html (I know, that interface
sucks and bugzilla is better, but currently we have no bugzilla);
2) nearest feature in raster or vector map?
If it is raster map, may bee You can write such module Yourself. I was
surprised, that knowledge from "teachyourself C in 24h" is enough to
code new simple raster module for GRASS. And more - first You can
implement it in mapcalc - it not as hard as it sounds :)
Let the source be with you!
Maris.
2006/1/16, Jesse Whittington <jesse.whittington at lycos.com>:
> When I run r.cost, I frequently receive an error saying that there is not enough memory.  After searching the mail archives I tried increasing my resolution four-fold, partitioning my grids with large overlapping boundaries, and adding the arguement percent_memory=100 with mixed success.  Consequently, it's easier for me to export my data and calculate distance to nearest feature in ArcInfo workstation.
> I realize that there are a limited number of developers, but I'm sending this message as a request for what might be a simpler algorythm than r.cost to produce:
>     - distance to nearest feature
>     - attribute of nearest feature
>     - direction to nearest feature
> Otherwise, I think GRASS is a GREAT program,
> Jesse
> Search for businesses by name, location, or phone number.  -Lycos Yellow Pages
> http://r.lycos.com/r/yp_emailfooter/http://yellowpages.lycos.com/default.asp?SRC=lycos10
