[GRASSLIST:9898] Re: Grass Mapserver Installation
Christian Ferreira
christian.grass at gmail.com
Wed Jan 18 07:24:03 EST 2006
Have you looked here?
http://grass.itc.it/start.html
On the README link there is this:
Markus Neteler/ITC-irst, Trento, Italy
neteler at itc.it
[$Date: 2002/02/06 15:04:40 $]
5 minutes MapServer installation (maybe 7 minutes)
[Requires MapServer 3.5 or later: http://mapserver.gis.umn.edu/ ]
[Requires libgrass: http://grass.itc.it/related_projects.html ]
[Requires GDAL: http://www.remotesensing.org/gdal/ ]
[Read also: http://www.remotesensing.org/gdal/frmt_grass.html ]
Compilation:
- libgrass
./configure ; make ; make install
ldconfig
- gdal
./configure --without-python --with-grass=/home/neteler/libgrass/gis
make ; make install
ldconfig
- mapserver
./configure --with-proj --with-ogr --with-gdal --with-gd --with-png
make ; make install
cp shp2img legend mapserv shptree shptreevis shptreetst scalebar sortshp \
tile4ms /usr/local/httpd/cgi-bin/
ldconfig
mapserver.map: map definitions (which maps to make available for MapServer)
- put in /usr/local/httpd/map-script/mapserver.map
spearfish.html: map template with page/map layout, zoom buttons etc.
- put in /usr/local/httpd/htdocs/
start.html: page to enter the mapserver (contains URL to cgi-bin)
.grassrc5: contains LOCATION and MAPSET and DATABASE definition for
SEPARFISH
Generate an empty temp directory:
- in /usr/local/httpd/htdocs/tmp/
To demonstrate, that this also works, store some exported GeoTIFF or SHAPE
here (export elevation.dem and roads from SPEARFISH):
- put in /usr/local/httpd/htdocs/spearfish/
Store start page:
Here we go:
http://localhost/start.html
Hint: Mapserver currently only displays 8bit/24bit Integer images.
Consider to rescale GRASS raster maps with r.rescale to 0..255
Enjoy. Tell your friends about it.
Maybe this is what you need.
Cheers,
On 1/18/06, siddhesh bhatkar <sid_grass at yahoo.com> wrote:
> Hello Everyone,
> I want to install the Grass mapserver Demo Version. I
> am using GRASS5.3 (I dont want to work at present with
> GRASS6.0). I have tried a lot but all in vain. The
> Raster Maps cannot be picked up from GRASS location.
> I get the following errors
> msDrawMap(): Image handling error. Failed to draw
> layer named 'geology'.
> msDrawRaster(): Image handling error. Unrecognized or
> unsupported image format
> drawEPP(): Image handling error.
> /var/www/GrassData/spearfish/PERMANENT/cellhd/geology
> is not an EPPL file.
> Can anyone give me a detailed step by step procedure
> to install a grass mapserver. Will be very greatful if
> anyone would take some time out to mail the procedure.
> Am new to this mailing group.
> Kindly help me out with this.
> Siddhesh,
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Christian dos Santos Ferreira
Oceanographer. Msc.
Lab. of Fisheries Research and Hydroacustics
Federal University of Rio Grande (FURG)
Rio Grande - RS - Brazil
Tel +55 (53) 32336528
Website: http://poseidon.furg.br
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060118/9e22ebcc/attachment.html
