[GRASSLIST:9901] Re: GeoTiffs shifted by 360 degrees after
processing in GRASS
Gross, Dorit (SDRN)
Dorit.Gross at fao.org
Wed Jan 18 08:30:52 EST 2006
Hi Markus,
Unfortunately the i.in.spotvgt script does not solve the problem. I can
import the Spot-Veg into Grass with the proper geometric reference. Instead,
the export back into GeoTiff (r.out.gdal) cannot handle the global
wrap-around and causes a 360 degree shift to the east. So might there be
another solution?
About i.in.spotvgt itself: I tried the import of the NDVI HDF without status
map and it seems to work nicely. Just a little note ... and maybe I have
overseen it ... it could be stated somewhere that also the log file is need
for the import.
Dorit
-----Original Message-----
From: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu] On
Behalf Of Markus Neteler
Sent: 16 January 2006 16:53
To: Gross, Dorit (SDRN)
Cc: GRASSLIST at baylor.edu
Subject: [GRASSLIST:9858] Re: GeoTiffs shifted by 360 degrees after
processing in GRASS
On Mon, Jan 16, 2006 at 04:44:57PM +0100, Gross, Dorit (SDRN) wrote:
> Dear all,
> I have a set of GeoTiffs that I import into GRASS to do some
> processing and export them afterwards as GeoTiffs again. The problem
> now is that GRASS exports the images shifted by 360 degrees to the
> east.
> Corner Coordinates (before the import into GRASS):
> Upper Left (-180.0044643, 75.0044643) (180d 0'16.07"W, 75d
> 0'16.07"N) Lower Left (-180.0044643, -56.0044643) (180d 0'16.07"W,
> 56d 0'16.07"S) Upper Right ( 179.9955353, 75.0044643)
> (179d59'43.93"E, 75d 0'16.07"N) Lower Right ( 179.9955353, -56.0044643)
(179d59'43.93"E, 56d 0'16.07"S)
> Center ( -0.0044645, 9.5000000) ( 0d 0'16.07"W, 9d30'0.00"N)
> Corner Coordinates (after the export from GRASS):
> Upper Left ( 179.9955357, 75.0044643) (179d59'43.93"E, 75d
> 0'16.07"N) Lower Left ( 179.9955357, -56.0044643) (179d59'43.93"E, 56d
0'16.07"S)
> Upper Right ( 539.996, 75.004) (539d59'43.93"E, 75d 0'16.07"N)
> Lower Right ( 539.996, -56.004) (539d59'43.93"E, 56d 0'16.07"S)
> Center ( 359.996, 9.500) (359d59'43.93"E, 9d30'0.00"N)
> Has someone of you faced a similar problem? How do I receive a proper
> georeference when exporting from GRASS?
> The input GeoTiffs are a set of converted Spot-Veg HDF files using
> GDAL.
Did you try to use the dedicated script i.in.spotvgt:
http://grass.itc.it/grass61/manuals/html61_user/i.in.spotvgt.html
Maybe this solves the problem of the global wrap-around.
Please let us know.
Markus
> The -180.0044... degrees for the upper left X seems a bit odd, but
> GDAL imports the Spot-Veg properly with these coordinates. I checked
> the images in Erdas and they are correct. I also checked the corner
> coordinates of the imported file insight GRASS and also here the
> coordinates are correct. So apparently the shift occurs during the
> export from GRASS into GeoTiff. At the moment I solve the problem by
> reassigning the georeference to the GeoTiff after the export from
> GRASS, but I would be more happy with properly exported images right
> away.
> Can someone help please?
> Thank you,
> Dorit
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica MPBA - Predictive
Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
