[GRASSLIST:9905] Re: Problems when compiling GRASS in an Opteron
Kenneth Cabrera krcabrer at epm.net.co
Wed Jan 18 20:36:00 EST 2006
Hi GRASS users:
Here is the program error when I try to start with the display manager
command.
With  the GRASS 6.0.2RC4 there is no compile (after the "make" command)
errors.
Welcome to GRASS 6.0.2RC4 (2006)
GRASS homepage:                          http://grass.itc.it/
This version running thru:               Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter:                exit
GRASS 6.0.2RC4 (etopo2):~ > Error in startup script: ps.map: error while
loading shared libraries: libgdal.so.1: cannot open shared object file:
No such file or directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 32)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.0.2RC4/etc/dm/d.m.tcl" line 894)
What  option should I use to compile the gdal library?
Thank you for your help.
Type: application/defanged
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060118/80f3a3b3/krcabrer.bin
