[GRASSLIST:9937] v.buffer and cat-values - bug?
Wolfgang Qual
Wolfgang.Qual at gmx.net
Fri Jan 20 07:23:20 EST 2006
Hi list,
using v.buffer I created a polygon-theme around a polyline-theme (v.buffer
input=themea output=themeb buffer=50 type=boundary,centroid). The strange
thing is that if I load the new polygon theme into GRASS (d.vect), some
white boundaries appear within the polygon. I used d.what.vect to see what's
behind them and I discovered that there are different cat-values. I would
have expected only spatially disconnected areas to have different
cat-values.
However, loading the theme into QGIS, I do not see any such white lines and
the query tool will not report different values for cat (only the value
"1").
Regards,
Wolfgang
Telefonieren Sie schon oder sparen Sie noch?
NEU: GMX Phone_Flat http://www.gmx.net/de/go/telefonie
