[GRASSLIST:9942] Re: compiling grass for cygwin
Maciek Sieczka
werchowyna at epf.pl
Sat Jan 21 10:27:39 EST 2006
On sob, 2006-01-21 at 15:20 +0100, Wolfgang Zillig wrote:
> OK,
> it seems that this is not really an easy task.
> Is there a simple way to get the dxf support running without compiling
> everything?
Grass 5.4 has v.in.dxf. For 6.x you would need to build GDAL/OGR with
OpenDWG http://www.opendesign.com/
Workaround if you want to work with 6.x (recommended):
1.install Grass 5.4
2. v.in.dxf
3. in 6.x, v.convert to import old Grass (5.x) vector into a new (6.x)
Maciek
Szukasz do¶wiadczonej firmy poligraficznej? Zale¿y Ci na terminowo¶ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
