[GRASSLIST:9954] Re: R, kriging and grass6
Vellinga, Olaf Olaf.Vellinga at wur.nl
Mon Jan 23 07:26:36 EST 2006
> If you like, we can iterate to a working example from passing
> the vector points to R from GRASS, doing the modelling and
> kriging predictions, and passing the prediction rasters back
> to GRASS, but I'd like input from users to make the description sound.
As a novice to this topic (exactly, I'm right now trying to dig into
it), this would be a great idea.
Best regards,
Olaf Vellinga
Wageningen UR
Alterra
Centre for Water & Climate
Team Land-Atmosphere Interactions
Address: www.sense.nl/researchers/vellinga
Global Met-Pages: www.globalmetpages.net
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> [mailto:owner-GRASSLIST at baylor.edu] On Behalf Of Roger Bivand
> Sent: maandag 23 januari 2006 13:15
> To: ivan marchesini
> Cc: grasslist-en
> Subject: [GRASSLIST:9953] Re: R, kriging and grass6
> On Mon, 23 Jan 2006, ivan marchesini wrote:
> > Hi to all...
> > we are triyng to use kriging using R and grass6, We have
> seen a lot of
> > documentation about R and GRASS5 but not so many about grass6...
> > the problem is that we are trying to do an interpolation using the
> > functions gmeta6 and kriging...
> > if we are not wrong, the R library GRASS is developed for
> grass5 and
> > inside there is the function krige.G that use the location data
> > acquired using the gmeta() function...
> > the problem is that we have found the gmeta6() function but not the
> > krige.G6 function and obvously the krige.G doesn't work using the
> > location data of grass6 (obtained using gmeta6)
> > how can we simply solve this problem....
> krige.G was a nasty hack, and should best be forgotten. The
> direct route is to use the sp classes in R and implemented
> for GRASS in spgrass6 - see GRASS News for the GRASS side and
> R News for the R side, combined with a proper R geostats
> package. Of those available, gstat is tightly bound to sp
> classes, so as far as I know, the only bit that needs doing
> by hand is to create a GridTopology object, or a SpatialGrid
> object, from the data returned by gmeta6() to pass to the
> kriging prediction function.
> Best wishes,
> Roger
> > thank you
> > Ivan
> Roger Bivand
> Economic Geography Section, Department of Economics,
> Norwegian School of Economics and Business Administration,
> Helleveien 30, N-5045 Bergen, Norway. voice: +47 55 95 93 55;
> fax +47 55 95 95 43
> e-mail: Roger.Bivand at nhh.no
