[GRASSLIST:9955] Re: R, kriging and grass6
Thomas Adams
Thomas.Adams at noaa.gov
Mon Jan 23 07:40:43 EST 2006
Roger,
I think your suggestion would be very beneficial — in general for many
GRASS & R uses such 'cookbook' examples would be greatly helpful.
Tom
Roger Bivand wrote:
>On Mon, 23 Jan 2006, ivan marchesini wrote:
>>Hi to all...
>>we are triyng to use kriging using R and grass6,
>>We have seen a lot of documentation about R and GRASS5 but not so many
>>about grass6...
>>the problem is that we are trying to do an interpolation using the
>>functions gmeta6 and kriging...
>>if we are not wrong, the R library GRASS is developed for grass5 and
>>inside there is the function krige.G that use the location data acquired
>>using the gmeta() function...
>>the problem is that we have found the gmeta6() function but not the
>>krige.G6 function and obvously the krige.G doesn't work using the
>>location data of grass6 (obtained using gmeta6)
>>how can we simply solve this problem....
>krige.G was a nasty hack, and should best be forgotten. The direct route
>is to use the sp classes in R and implemented for GRASS in spgrass6 - see
>GRASS News for the GRASS side and R News for the R side, combined with a
>proper R geostats package. Of those available, gstat is tightly bound to
>sp classes, so as far as I know, the only bit that needs doing by hand is
>to create a GridTopology object, or a SpatialGrid object, from the data
>returned by gmeta6() to pass to the kriging prediction function.
>If you like, we can iterate to a working example from passing the vector
>points to R from GRASS, doing the modelling and kriging predictions, and
>passing the prediction rasters back to GRASS, but I'd like input from
>users to make the description sound.
>Best wishes,
>Roger
>>thank you
>>Ivan
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
