[GRASSLIST:9963] Re: R, kriging and grass6
Kirk R. Wythers
kwythers at umn.edu
Mon Jan 23 16:40:15 EST 2006
Roger,
Thanks for putting this together. I do have a very basic question
about getting the vector points from a GRASS vector to R. Can you
roll this description back a couple of steps and start with a GRASS
vector? Is this example based on the maas data?
Kirk
On Jan 23, 2006, at 2:09 PM, Roger Bivand wrote:
> This is the dense version, feedback welcome!
> library(spgrass6) # load package running within GRASS 6
> meuse <- getSites6sp("meuse") # get vector points as
> SpatialPointsDataFrame
> class(meuse)
> G <- gmeta6() # get region
> grd <- GridTopology(cellcentre.offset=c(G$west+(G$ewres/2),
> G$south+(G$nsres/2)), cellsize=c(G$ewres, G$nsres),
> cells.dim=c(G$cols, G$rows))
> mask_SG <- SpatialGridDataFrame(grd, data=list(k=rep(1, G$cols*G
> $rows)),
> proj4string=CRS(G$proj4)) # create a SpatialGridDataFrame
> class(mask_SG)
> cvgm <- variogram(zinc~1, loc=~x+y, data=meuse, width=100,
> cutoff=1000)
> efitted <- fit.variogram(cvgm, vgm(psill=1, model="Exp", range=100,
> nugget=1))
> OK_pred <- krige(id="OK_pred", formula = zinc ~ 1, locations = ~ x
> + y,
> data = as(meuse, "data.frame"), newdata=mask_SG, model=efitted)
> # make the kriging prediction
> names(OK_pred)
> writeRast6sp(OK_pred, "OK_pred", zcol = "OK_pred.pred", NODATA=-9999)
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060123/1353b940/attachment.html
