[GRASSLIST:9978] errors on make command
Pierluigi De Rosa sisma66 at tiscali.it
Tue Jan 24 17:12:16 EST 2006
Dear Grass users,
I'm tring to compile grass61,
the configure command seems work fine (this is the output:
GRASS is now configured for:  i686-pc-linux-gnu
 Source
directory:            /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21
 Build
 Installation directory:      /usr/local/grass-6.1.cvs
 Startup script in directory: ${exec_prefix}/bin
 C compiler:                  gcc -g -O2
 C++ compiler:
 FORTRAN compiler:
 Building shared libraries:   yes
 64bit support:               no
  NVIZ:                       yes
  BLAS support:               no
  C++ support:                no
  DWG support:                no
  FFMPEG support:             no
  FFTW support:               yes
  FreeType support:           no
  GDAL support:               yes
  GLw support:                no
  JPEG support:               yes
  LAPACK support:             no
  Large File Support (LFS):   no
  Motif support:              no
  MySQL support:              no
  NLS support:                no
  ODBC support:               no
  OGR support:                yes
  OpenGL(R) support:          yes
  PNG support:                yes
  PostgreSQL support:         yes
  Readline support:           no
  SQLite support:             no
  Tcl/Tk support:             yes
  TIFF support:               yes
  X11 support:                yes
theh I run make command and I have errors in the follows (and more)
modules:
cp -f AUTHORS COPYING README
REQUIREMENTS.html /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/dist.i686-pc-linux-gnu/
cp -
f /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/bin.i686-
pc-linux-
gnu/grass61 /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/dist.i686-pc-linux-gnu/grass61.tmp
build_html_index.sh
cp: impossibile creare il file normale `../dist.i686-pc-linux-
gnu/docs/html/../nviz/grassdocs.css': No such file or directory
gnu/docs/html/../nviz/grass.smlogo.gif': No such file or directory
Generating HTML manual pages index (help system)...
Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
Following modules are missing the 'description.html' file in src code:
g.pnmcomp
GRASS GIS compilation log
Started compilation: mar gen 24 22:51:54 CET 2006
Errors in:
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/proj
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/vector/diglib
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/vector/Vlib
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/sites
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/rst/interp_float
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/ogsf
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/db/drivers/ogr
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.extend
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.grid
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.path
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.vect
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.vect.chart
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.what.vect
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.where
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/display/d.zoom
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/general/g.proj
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/general/g.region/cmd
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/general/manage/lib
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/general/manage/cmd
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/general/manage/lister
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/imagery/i.vpoints
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/ps/ps.map
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.carve
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.contour
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.cost
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.drain
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.flow
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.le/r.le.setup
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.proj
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.random
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.region
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.resamp.rst
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.sun
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.sunmask
/home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/raster/r.to.vect
so when I start grass61 I find this errors:
GRASS homepage:                          http://grass.itc.it/
This version running thru:               Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter:                exit
Error in startup script: couldn't execute "ps.map": no such file or
directory
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 34)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 1613)
can anyone help me??
I use mandrake 10.1 community
Thanks to all
Pierluigi
