[GRASSLIST:9980] Re: configure: error: *** Unable to locate GDAL
library.
Hamish
hamish_nospam at yahoo.com
Tue Jan 24 17:47:53 EST 2006
> Even though i have installed gdal-1.1.9 on my linux
> system.
that is a very old version now, consider upgrading.
> On running the ./configure command for installing
> grass-6.0.0 i get the following error
> checking for GDALOpen... no
> configure: error: *** Unable to locate GDAL library.
> These r the files tht are present in the below
> mentioned directories
> /usr/lib/libgdal.1.1.so
> /usr/local/lib/libgdal.so.1.4.1
> /usr/local/lib/libgdal.la
> /usr/local/lib/libgdal.a
> /usr/local/lib/libgdal.1.1.so
make sure that /usr/local/lib is listed in your /etc/ld.so.conf file and
(as root) run /sbin/ldconfig.
I have added this suggestion to the Wiki FAQ page:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassFAQPage
Hamish
