[GRASSLIST:9988] Re: configure: error: *** Unable to locate GDAL library.
Rochelle MIranda
r0chelle_miranda at yahoo.com
Wed Jan 25 00:44:48 EST 2006
Hello Hamish
I ran both the commands and these are the location of
gdal-config and libgdal.
locate gdal-config
/usr/local/bin/gdal-config
locate libgdal
/usr/lib/libgdal.1.1.so
/usr/local/lib/libgdal.so.1
/usr/local/lib/libgdal.so.1.4.1
/usr/local/lib/libgdal.la
/usr/local/lib/libgdal.a
/usr/local/lib/libgdal.1.1.so
R0chelle
--- Hamish <hamish_nospam at yahoo.com> wrote:
> > As u said i added /usr/local/lib to the
> > /etc/ld.so.conf as root and ran ldonfig.Do i need
> to
> > relogin into my system for the changes to come to
> > effect?
> No, as soon as ldonfig is done it should be ok.
> try:
> $ locate gdal-config
> $ locate libgdal
> where are they?
> > I tried installing grass-6.0.0 but it gives me the
> > same errors as before.
> >> On running the ./configure command for installing
> >> grass-6.0.0 i get the following error
> >> checking for GDALOpen... no
> library.
> look at the end of config.log for the error.
> > Also as u suggested i tried installing latest
> version
> > of gdal.
> > when i run the "make" command for installing
> > gdal-1.3.1
> > i get following errors errors
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory
> `/home/r0chelle/gdal-1.3.1'
> > make: *** [check-lib] Error 2
> > r these packages not debugged already?
> We need to see a dozen or so lines prior to that as
> well. That just
> tells us where it stopped, not why.
> Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
