[GRASSLIST:9991] Re: errors on make command
Pierluigi De Rosa
sisma66 at tiscali.it
Wed Jan 25 02:33:34 EST 2006
I tried to run make into a dorectory and the usefull errors are about
"permission denied", so I run make as root ad now it seems work fine.
Thanks Hamish
Pierluigi
Il giorno mer, 25-01-2006 alle 18:41 +1300, Hamish ha scritto:
> > I'm tring to compile grass61,
> > the configure command seems work fine (this is the output:
> > GRASS is now configured for: i686-pc-linux-gnu
> > C compiler: gcc -g -O2
> > C++ compiler:
> > FORTRAN compiler:
> > Building shared libraries: yes
> > 64bit support: no
> > NVIZ: yes
> > BLAS support: no
> > C++ support: no
> > DWG support: no
> > FFMPEG support: no
> > FFTW support: yes
> > FreeType support: no
> > GDAL support: yes
> > GLw support: no
> > JPEG support: yes
> > LAPACK support: no
> > Large File Support (LFS): no
> > Motif support: no
> > MySQL support: no
> > NLS support: no
> > ODBC support: no
> > OGR support: yes
> > OpenGL(R) support: yes
> > PNG support: yes
> > PostgreSQL support: yes
> > Readline support: no
> > SQLite support: no
> > Tcl/Tk support: yes
> > TIFF support: yes
> > X11 support: yes
> > theh I run make command and I have errors in the follows (and more)
> > modules:
> > cp: impossibile creare il file normale `../dist.i686-pc-linux-
> > gnu/docs/html/../nviz/grassdocs.css': No such file or directory
> > gnu/docs/html/../nviz/grass.smlogo.gif': No such file or directory
> > Generating HTML manual pages index (help system)...
> > Generated HTML docs in ../dist.i686-pc-linux-gnu/docs/html/index.html
> > Following modules are missing the 'description.html' file in src code:
> > g.pnmcomp
> > GRASS GIS compilation log
> > Started compilation: mar gen 24 22:51:54 CET 2006
> > Errors in:
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/proj
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/vector/diglib
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/vector/Vlib
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/sites
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/rst/interp_float
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/ogsf
> > /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/db/drivers/ogr
> start with these.
> cd into the directory and type "make". It should end with a useful error
> message. Once the libraries and drivers are compiled the modules should
> too.
> cd /home/pierluigi/GRASS/grass-6.1.cvs_src_snapshot_2006_01_21/lib/proj
> make
> Hamish
