[GRASSLIST:10004] Re: Filling with flood
Māris Nartišs
maris.nartiss at gmail.com
Wed Jan 25 10:34:42 EST 2006
How I did it:
Creating dam:
1) With r.digit digitise map dam line; Assign correct height to it;
2) Grow it to 2 cells atleast to avoid any holes in dam;
3) With r.mapcalc add dam to DEM.
Filling lake:
1) With r.digit create map with atleast one cell with any value below
target water level (seed);
2) Feed in DEM, seed, target water level to r.lake.
You'r done!
Maris.
Attached:
sm_ice.jpg - screenshot form movie showing Smiltene palaeolake and
possible ice margin, north Vidzeme, Latvia. Created with described
steps, only instead of r.lake I used r.mapcalc with script (~20h to
get such map on P4 3GHz compared to 1min on 800MGz PIII with r.lake).
r_lake.zip - source code of new GRASS module. Use at Your own risk!
Currently it lacks nice blue color gradient for output maps. Any
comments - welcome.
2006/1/25, RAVI KUMAR <ravivundavalli at yahoo.com>:
> Hi
> It will be nice if I can get a workedout example
> where in a DEM is used to create a Dam and then flood it.
> Ravi
> Hamish <hamish_nospam at yahoo.com> wrote:
> > I have a surface of watershed and wish to simulate a dam
> > to see the area of inundation (flooding).
> > Please suggest a simple method in GRASS6 to create a reservoir (Dam)
> d.rast.edit or r.digit+r.patch to make the dam, then use r.basins.fill?,
> r.fill.dir? or the module recently (in the last month) announced on the
> mailing list to fill depressions & r.mapcalc to compare/crop.
> Hamish
> ________________________________
> Bring words and photos together (easily) with
> PhotoMail - it's free and works with your Yahoo! Mail.
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20060125/73db9c01/sm_ice.jpg
