[GRASSLIST:10006] Re: " make" errors while compiling gdal-1.3.1
Wed Jan 25 10:53:11 EST 2006
Rochelle MIranda wrote:
> These are some of the few lines preceeding the error
> messages. hope this will help u diagnos the
> problem.Please look in.
> /usr/lib/libnetcdf.a(attr.o)(.text+0x3f0): In function `NC_findattr':
> : multiple definition of `NC_findattr'
> /usr/lib/libmfhdf.a(attr.o)(.text+0x1e0): first defined here
Versions of the HDF library which include built-in NetCDF support will
conflict with a separate NetCDF library. You will need to disable
either NetCDF or HDF support.
