[GRASSLIST:10018] Can anyone help me compile gdal-1.3.1.tar.gz?
Rochelle MIranda
r0chelle_miranda at yahoo.com
Thu Jan 26 23:34:05 EST 2006
Hi everyone,
I want to install gdal-1.3.1.tar.gz the latest version
of gdal on my linux system.
The ./configure command is executed successfully.
But when i run the "make" command , i get the
following 2 errors.
/usr/lib/libnetcdf.a(attr.o)(.text+0x3f0): In function
`NC_findattr':
: multiple definition of `NC_findattr'
/usr/lib/libmfhdf.a(attr.o)(.text+0x1e0): first
defined here
/usr/bin/ld: Warning: size of symbol `NC_findattr'
changed from 124 in /usr/lib/libmfhdf.a(attr.o) to 140
/usr/lib/libnetcdf.a(nc.o)(.text+0x60): In function
`NC_check_id':
: multiple definition of `NC_check_id'
/usr/lib/libmfhdf.a(file.o)(.text+0x0): first defined
here
/usr/bin/ld: Warning: size of symbol `NC_check_id'
changed from 67 in /usr/lib/libmfhdf.a(file.o) to 61
/usr/lib/libnetcdf.a(var.o)(.text+0x5b0): In function
`NC_var_shape':
: multiple definition of `NC_var_shape'
/usr/lib/libmfhdf.a(var.o)(.text+0x1d0): first defined
here
/usr/bin/ld: Warning: size of symbol `NC_var_shape'
changed from 520 in /usr/lib/libmfhdf.a(var.o) to 373
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/home/bnagesh/gdal-1.3.1'
make: *** [check-lib] Error 2
And also some warning messages as follows:
GNUmakefile:44: warning: overriding commands for
target `libgdal.la'
GNUmakefile:40: warning: ignoring old commands for
target `libgdal.la'
Can anyone tell me how to rectify these errors. does
gdal-1.3.1 requires to be debugged here? I have been
trying since yesterday. but to no avail.
Kindly look into this.
Thanking everyone in advance.
Rochelle.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
