[GRASSLIST:10043] Re: OS X Binary Issue
Stuart Edwards sedwards2 at cinci.rr.com
Mon Jan 30 09:10:02 EST 2006
I've had a similar experience -- erratic start-up, but without the
error message. It seems to occur if GIS manager and/or X windows were
not shut down properly after the previous session.  If they are, it
starts up ok.
Stuart
On Jan 29, 2006, at 10:52 AM, David Kindem wrote:
> I've recently downloaded the latest Grass 6.1 binary fromOS X
> binary form Lorenzo's site (dated 24 Jan 2006).  As in the past,
> I've dragged the new file to the Grass folder and replaced the
> previous version.
> I am not able to launch Grass with the new version.  I select start
> from the first screen, and receive the following error:
> dyld: Library not loaded: /usr/local/grasslib/lib/libintl.3.dylib
>   Referenced from: /Applications/Grass/grass61cvs.app/Contents/
> Resources/grass-6.1.cvs/etc/clean_temp
>   Reason: image not found
> At this point Grass appears to be starting.  I select my location
> and mapset but when I try to enter Grass, the program crashes.
> There are other error messages in the terminal screen, but the
> terminal window does not stay open, and I cannot read what they were.
> Is anyone else having problems with this release?
> Dave
