[GRASSLIST:10083] Re: trying to read in ArcView/.mdb file of NYC roads
Markus Neteler
neteler at itc.it
Tue Jan 31 08:34:49 EST 2006
Again, is this the CVS version of mdb?
In any case, the mdb mailing list would be right
to post the report.
Markus
On Tue, Jan 31, 2006 at 08:30:41AM -0500, U. George wrote:
> yup, ur right: Now for a segfault to brighten this day
> mdb-schema /tmp/lion/Data/LION.mdb
> DROP TABLE ALTNAMES;
> CREATE TABLE ALTNAMES
> OBJECTID Long Integer (4),
> PDIR Text (4),
> PTYPE Text (12),
> SNAME Text (60),
> STYPE Text (12),
> SDIR Text (4),
> JOIN_ID Text (30)
> -- CREATE ANY INDEXES ...
> DROP TABLE GDB_AnnoSymbols;
> CREATE TABLE GDB_AnnoSymbols
> Symbol OLE
> DROP TABLE GDB_AttrRules;
> CREATE TABLE GDB_AttrRules
> RuleID Long Integer (4),
> Subtype Long Integer (4),
> FieldName Text (510),
> -- CREATE ANY Relationships ...
> relationships are not supported for access
> Segmentation fault
> Markus Neteler wrote:
> >On Tue, Jan 31, 2006 at 08:12:26AM -0500, U. George wrote:
> >>got and compiled the src. not readable! :-{
> >>> mdb-ver /tmp/lion/Data/Lion.mdb
> >>Can't alloc filename
> >ls -la /tmp/lion/Data/Lion.mdb
> >Also:
> >IMHO the CVS version is more advanced than the 0.5 release.
> >Markus
> >>>U. George wrote:
> >>>>from the website:
> >>>>http://www.nyc.gov/html/dcp/html/bytes/dwnlion.shtml
> >>>>i would like to view the roads in the bronx. I am not familiar with
> >>>>either grass, or arcview.
> >>>>I have built 'grass' from source. But am unable to import the
> >>>>LION.mdb data file.
> >>>>GRASS 6.0.1 (GRASS):/tmp/lion > unzip -l nyc_lion05bav.zip
> >>>>Archive: nyc_lion05bav.zip
> >>>>Length Date Time Name
> >>>> 15360 05-10-05 14:59 LION Streets.lyr
> >>>> 18432 05-10-05 14:52 LION.lyr
> >>>> 27640 05-02-05 13:53 NYC LION Geocoding (GDB).lot
> >>>> 27201 05-10-05 11:44 NYC LION Geocoding (SDE).lot
> >>>>133436 08-02-05 10:11 nyc_lion_metadata.htm
> >>>>48627712 08-02-05 10:08 Data/LION.mdb
> >>>> 0 07-11-05 12:21 Data/
> >>>>109568 07-20-05 12:34 Geocoding with LION.doc
> >>>>48959349 8 files
> >>>You may use:
> >>>http://mdbtools.sourceforge.net/
> >>>" The MDB Tools project is a effort to document the MDB file format
> >>>used in Microsoft <http://www.microsoft.com/>'s Access database
> >>><http://www.microsoft.com/office/access/default.asp> package, and to
> >>>provide a set of tools and applications to make that data available on
> >>>other platforms."
> >>>Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
