[GRASS-user] Re: ./configure error with gdal-grass-1.3.1.2
Hamish
hamish_nospam at yahoo.com
Sun Jul 2 01:45:44 EDT 2006
David wrote:
> ...but the problem persists.
> Then I editing ld.so.conf to point to the /usr/local/grass-6.1.cvs and
> not the source directory, ran ldconif and then
/etc/ld.so.conf needs to be pointed to the LIBS dir.
for a hint, in grass try:
echo $GRASS_LD_LIBRARY_PATH
or
echo $GISBASE/libs
then run ldconfig again.
> ./configure --with-gdal=/usr/local/bin/gdal-config
> --with-grass=/usr/local/grass-6.1.cvs/include
^^^^^^^^^^^^^^ this should be "ARG=GRASS install tree dir"
echo $GISBASE
Hamish
