[GRASS-user] libgrass_vect.so in grass6.1-cvs broken?
    Florian Kindl
    Florian.Kindl at uibk.ac.at
    Mon Jul  3 07:10:32 EDT 2006
Hello list!
I tried to compile today's grass6.1:
`./configure --with-cxx --with-postgres-libs=/usr/local/pgsql/lib \
--with-postgres-includes=/usr/local/pgsql/include`
leads to:
  C compiler:                  gcc -g -O2
  C++ compiler:                c++ -g -O2
  FORTRAN compiler:
  Building shared libraries:   yes
  64bit support:               no
   NVIZ:                       yes
   BLAS support:               no
   C++ support:                yes
   DWG support:                no
   FFMPEG support:             no
   FFTW support:               yes
   FreeType support:           no
   GDAL support:               yes
   GLw support:                no
   JPEG support:               yes
   LAPACK support:             no
   Large File Support (LFS):   no
   Motif support:              no
   MySQL support:              no
   NLS support:                no
   ODBC support:               no
   OGR support:                yes
   OpenGL(R) support:          yes
   PNG support:                yes
   PostgreSQL support:         yes
   Readline support:           no
   SQLite support:             no
   Tcl/Tk support:             yes
   TIFF support:               yes
   X11 support:                yes
... which looks OK to me.
When I run `make`, it gives errors in most directories.
Descending to one of them and running `make` there results in the
following error:
make: *** No rule to make target
`/home/fkindl/svnrepos/grass6/dist.i686-pc-linux-gnu/lib/libgrass_vect.so',
needed by
`/home/fkindl/svnrepos/grass6/dist.i686-pc-linux-gnu/bin/v.what'.  Stop.
libgrass_vect.so has not been built! - any ideas why that is?
grass6.0.2 sources build OK on the same machine.
yours,
\Flo.
Florian Kindl
Institut für Geographie
Universität Innsbruck
