[GRASS-user] Vlib: add attributes to new vector
Florian Kindl Florian.Kindl at uibk.ac.at
Thu Jul 6 09:36:59 EDT 2006
Hello list!
I started to write a vector module for GRASS GIS.
It reads an existing vector set (lines) and writes a new one.
The output set should contain the attributes of the input set plus 2 new
attributes which are calculated by my module.
How do I append these new attribute columns to my output data?
When I use
Vect_copy_tables ( &In, &Out, 0 );
can I, afterwards,  add colums to the table of &Out?
Or do I have to add another table like this:
==code==
     Fi = Vect_default_field_info ( &Out, 1, NULL, GV_1TABLE );
     Vect_map_add_dblink ( &Out, 1, NULL, Fi->table, "cat", Fi->database,
Fi->driver);
     driver = db_start_driver_open_database ( Fi->driver, Fi->database );
     if ( driver == NULL )
     G_fatal_error ( "Cannot open database %s by driver %s", Fi->database,
Fi->driver );
     sprintf ( buf, "create table %s ( cat integer, bsnid integer, sorder
integer )", Fi->table );
     db_set_string ( &sql, buf );
     G_debug ( 2, db_get_string ( &sql ) );
     if (db_execute_immediate (driver, &sql) != DB_OK ) {
         db_close_database_shutdown_driver ( driver );
     G_fatal_error ( "Cannot create table: %s", db_get_string ( &sql )  );
==/code==
(these lines work if there is no table yet - it fails if one already
exists)
And finally, can someone explain the concept of dblink,tables,fields,
layers concisely? I don't get it yet from the documents on the GRASS
6 vector architecture...
Thanks for your help,
Flo.
Florian Kindl
Institute ofr Geograpy
University of Innsbruck
