[GRASS-user] v.in.gpsbabel problem
Mike Dvorak
mike at mikemath.net
Sun Jul 9 12:17:20 EDT 2006
Also, I'm confused because on lines 241 and 246 of v.in.gpsbabel, there
are two gpsbabel commands that are not even valid according to the GPS
babel documentation:
% gpsbabel -r -i $GIS_OPT_FORMAT $GPSdevice $PROGVERBOSE -o \
gpx,style="$STYLE" -F "$TMP".gpx
The "-o gpx" command cannot take the "style" option. I've tried
removing this extraneous style argument but the program still seems to
crash unfortunately.
Cheers,
-Mike
Mike Dvorak wrote:
> I should also mention that v.in.gpsbabel works just fine for waypoints,
> but not tracks. This is the command that I was trying to run:
> % v.in.gpsbabel input=/dev/cu.KeySerial1 output=prospect_park_r9
> format=garmin -t
> Cheers,
> -Mike
> Mike Dvorak wrote:
>> Dear GRASS users,
>> I'm having a problem with v.in.gpsbabel for GRASS-6.1 (cvs, 24 Jun 2006)
>> on OS X. The "gpsbabel" command fails with a syntax error initially,
>> which leads to all kinds of other errors in the script. I tried copying
>> over the latest script version from CVS and it v.in.gpsbabel script
>> fails in the same way. Here's the first part of the failing output:
>> Uploading Tracks from GPS
>> 'style=/Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/etc/grass_write_ascii.style'
>> is an unknown option to gpx.
>> /Applications/Grass/grass61cvs.app/Contents/Resources/grass-6.1.cvs/scripts/v.in.gpsbabel.r3:
>> line 459: ((: OFFSET=117-: syntax error: operand expected (error token
>> is "-")
>> tail: option requires an argument -- n
>> usage: tail [-F | -f | -r] [-b # | -c # | -n #] [file ...]
>> line 459: ((: OFFSET=132-: syntax error: operand expected (error token
>> is "-")
>> Attempting waypoint projection transform with cs2cs
>> Importing with v.in.ascii
>> Building topology ...
>> Registering lines:
>> 3 primitives registered
>> Building areas:
>> v.in.gpsbabel.r3: line vector "prospect_park_r6 at PERMANENT" successfully
>> created
>> Creating new table..
>> Populating table with attributes..
>> DBMI-DBF driver error:
>> SQL parser error in statement:
>> INSERT INTO prospect_park_r6 VALUES (1, ' ', , , ' ', , )
>> I should also mention that I had to replace the "stat -c%s..." command
>> with "stat -fz..." to get it working on OS X too. Can anyone help me
>> with this? I'm trying to get a demo working for an open source GIS talk
>> I'm giving in a couple of weeks at the HOPE6 conference. I wish that I
>> had a Linux box available to me, but unfortunately that's not the case.
>> Cheers,
>> -Mike
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
