[GRASS-user] how to create multiband/hyperspectral
Robert Kuszinger
kuszinger at giscom.hu
Wed Jul 12 01:56:37 EDT 2006
Michael,
thanks, that's really what I've found and thenks for your answer making
it clear that there are no other tools for this.
My actual problem is to have e.g. 14 bands for a single area. I'm
planning to play with displaying compisosite variations withount
createing r.composite or r.rgb files for all possible combinations BUT -
reading you answer finally I found what I need:
d.rgb :)
I could easily drop in rasters (eg. bands) and play with my combinations.
thanks!
Robert
> Robert,
> It isn't clear what you want to do. If you want to patch together adjacent
> images (i.e., rasters covering different geographic areas), use r.patch.
> If you want to make a color image out of 3 bands, use d.rgb to just display
> a color image, or r.composite to combine 3 bands into a new color image
> file.
> GRASS stores all individual 'bands' as separate rasters that you can
> combine, analyze, and process in multiple ways. It does not combine multiple
> bands into a single 'file'.
> Some processes can deal with a group of images/bands covering the same
> geographic area as a 'group'. A group is created with i.group. But a 'group'
> is simply a reference to a set of images; it does not combine them into a
> single multi-band file. This is unnecessary with GRASS.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Robert Kuszinger <kuszinger at giscom.hu>
>> Date: Tue, 11 Jul 2006 06:59:59 +0200
>> To: <grassuser at grass.itc.it>
>> Subject: [GRASS-user] how to create multiband/hyperspectral
>> Hello!
>> I give up - cannot find the solution. :)
>> I've created a python script to automatically process ASTER CD-s and
>> create all the raster layers in grass from a given CD automatically. Now
>> I have a LOT of raster layers.
>> *** I would like to join raster layers covering the same area *** to
>> make only one file for one area. So, how to make a multispectral file
>> using several raster layers? I have 3-14 bands I'd like to join per image
>> How to make it?
>> I checked grass documentation, commands, but simply cannot figure how to
>> make it.
>> I realized that there is an i.group command - that could be fine for
>> rasters as well...
>> Maybe the answer is too simmple, that's why I can't find.
>> Thanks for any help
>> Robert
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060712/71400215/attachment.html
