[GRASS-user] Can't start GRASS 6.0.0
María Piquer Rodríguez
almecloud at hotmail.com
Thu Jul 13 06:00:38 EDT 2006
Hello again Marco,
I found out (http://sourceware.org/ml/cygwin/2004-02/msg01139.html) that
choosing the Internet connection as "Use IE5 Settings" should not be a
problem. And indeed I don't get the error: "Can't get list of download
sites. Make sure your network settings are correct and try again", when I
choose "Use IE5 Settings". Actually the setup.exe is done but for isntance
the proj folder with all the EPSG codes is not installed : instead of
"/usr/local/share/proj/epsg" I have "\usr\local\share(dor or gadal, but not
pro)" .... (??)
Now The error I still get is when trying to start Grass 60:
Welcome to GRASS 6.0.0 (2005)
GRASS homepage: http://grass.itc.it/
This version running thru: GNU Bash (Cygwin)
(/usr/bin/bash.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter: exit
GRASS 6.0.0 (test1):~ > Error in startup script: child process exited
abnormally
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 32)
invoked from within
"main $argc $argv"
(file "/usr/local/grass6.0.0/etc/dm/d.m.tcl" line 894)
Therefore I cannot start GRASS, stil....
and when I try to create a location by using the EPSG I get:
Warning- The epsg-code file was not found!!! when clicking in
the codes browser. This is clear as it does not exist in the correct
directory.
Here I do have proj.4 installed but a
version from may 2004 (just in case this info helps)
cs2cs
Rel. 4.4.8, 3 May 2004
usage: cs2cs [ -eEfIlrstvwW [args] ] [ +opts[=arg] ]
[+to [+opts[=arg] [ files ]
I don't know if I am not able to install it, if the programm terms are too
dificult for me, that I don't have a UNIX working background or if I am
doing somenthig so wrong... but I spend already 4 days with the installation
with no success.... :-s
Thank you very much to all,
María
>From: "Marco Lechner" <marco.lechner at geographie.uni-freiburg.de>
>To: 'María Piquer Rodríguez' <almecloud at hotmail.com>
>Subject: AW: AW: AW: AW: [GRASS-user] Can't start GRASS 6.0.0
>Date: Wed, 12 Jul 2006 15:15:59 +0200
>So it's a cygwin problem:
>http://www.cygwin.com/ml/cygwin/2004-08/msg00487.html
>Marco
> > -----Ursprüngliche Nachricht-----
> > Von: María Piquer Rodríguez [mailto:almecloud at hotmail.com]
> > Gesendet: Mittwoch, 12. Juli 2006 15:10
> > An: marco.lechner at geographie.uni-freiburg.de
> > Betreff: RE: AW: AW: AW: [GRASS-user] Can't start GRASS 6.0.0
> > Hello Marco,
> > I did the installation as it is especified at
> > http://geni.ath.cx/grass.html#toc2 but at the step for
> > setting the internet connection I cannot set Direct connect (
> > I get this error: Can't get list of download sites. Make sure
> > your network settings are correct and try again) but Use IE5
> > Settings. The rest I do it the same as in
> > http://geni.ath.cx/grass.html#toc2 .
> > Then when I try to start Grass 60 I get this error:
> > (/usr/bin/bash.exe)
> > GRASS 6.0.0 (spearfish60):~ > Error in startup script: child
> > process exited abnormally
> > while executing
> > "exec ps.map -p"
> > invoked from within
> > "DmPrint::init"
> > invoked from within
> > "main $argc $argv"
> > the codes browser. Here I do have proj.4 installed but a
> > cs2cs
> > and there is where I am stucked :-s
> > Any idea is more than wellcomed.
> > Cheers,
> > María
> > >Subject: AW: AW: AW: [GRASS-user] Can't start GRASS 6.0.0
> > >Date: Wed, 12 Jul 2006 15:00:17 +0200
> > >You have to put in http://geni.ath.cx/grass/ as a ADDITIONAL
> > >packagesource during the cygwin installation! The folder
> > >http://geni.ath.cx/grass/ is not accessible by a browser
> > ecause there
> > >is no directory listing!
> > >Marco
> > >P.S: it's written down step by step at
> > >if you already have the setup.exe from cygwin just execute it and
> > >follow the steps
> > >...or install the old version from my CD-Image ;-)
> > > > Gesendet: Mittwoch, 12. Juli 2006 14:56
> > > > Betreff: RE: AW: AW: [GRASS-user] Can't start GRASS 6.0.0
> > > > Hi Marco,
> > > > I can access: http://geni.ath.cx/grass.html and from there I
> > > > downloaded the setup.exe from http://cygwin.com.
> > > > When I type in: http://geni.ath.cx/grass/
> > > > I get:
> > > > Forbidden
> > > > You don't have permission to access /grass/ on this server.
> > > > Apache/1.3.29 Server at geni.ath.cx Port 80
> > > > So.... I believe that I am doing something wrong, am I?
> > or that the
> > > > server at work just does not allow me to install GRASS....
> > > > Thanks,
> > > > María
> > > > >Subject: AW: AW: [GRASS-user] Can't start GRASS 6.0.0
> > > > >Date: Wed, 12 Jul 2006 14:39:41 +0200
> > > > >Hi Maria,
> > > > >It depends if you want a uptodate-Version using the uptodate
> > > > cygwin and
> > > > >uptodate grass, or if you just want a working
> > cygwin-version and a
> > > > >working GRASS to do some GIS things.
> > > > >Marco
> > > > >P.S. By the way - the Version distributed by Huidao Cho normally
> > > > >doesn't produce any problems while installing. Did you
> > really add
> > > > >"http://geni.ath.cx/grass" as source? Not just
> > > > "http://geni.ath.cx" as
> > > > >described at http://geni.ath.cx/grass.html#toc6 ?
> > > > > > Gesendet: Mittwoch, 12. Juli 2006 13:36
> > > > > > Betreff: RE: AW: [GRASS-user] Can't start GRASS 6.0.0
> > > > > > Hi Marco,
> > > > > > Thank you very much. Do you also recomend me to intall
> > > > the programm
> > > > > > from a CD??
> > > > > > Cheers,
> > > > > > María
> > > > > > >To: "'Nagesh Bhatkar'" <bnagesh at nio.org>,'María
> > Piquer Rodríguez'
> > > > > > >CC: <grassuser at grass.itc.it>
> > > > > > >Subject: AW: [GRASS-user] Can't start GRASS 6.0.0
> > > > > > >Date: Wed, 12 Jul 2006 13:25:02 +0200
> > > > > > > Hi Nagesh and Maria,
> > > > > > >As "producer" of the CygwinGRASS-Image I just have to point
> > > > > > out, that
> > > > > > >it is based on a GRASS-CVS-Version from Spring 2005 (but it
> > > > > > works well
> > > > > > >- just doesn't inlude all the features developed since then)
> > > > > > >Marco
> > > > > > > > Von: grassuser-bounces at grass.itc.it
> > > > > > > > [mailto:grassuser-bounces at grass.itc.it] Im Auftrag von
> > > > > > > > Nagesh Bhatkar
> > > > > > > > Gesendet: Mittwoch, 12. Juli 2006 12:06
> > > > > > > > An: María Piquer Rodríguez
> > > > > > > > Cc: grassuser at grass.itc.it
> > > > > > > > Betreff: Re: [GRASS-user] Can't start GRASS 6.0.0
> > > > > > > > Hello Maria,
> > > > > > > > Instead of installing from the internet directly , i
> > > > installed
> > > > > > > > it from a CD. Found it more convinient.
> > > > > > > > First i downloaded the .iso image file and then burnt
> > > > it on a CD.
> > > > > > > > Given below is the link for downloading the .iso
> > image file
> > > > > > > > (~500MB) for installing cygwin GRASS
> > https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS
> > > > > > > > /C
> > > > > > >ygwinGRASS-0.4.iso
> > > > > > > > This single image file when burnt onto a CD, forms
> > > > the following
> > > > > > > > files and folders on it:
> > > > > > > > autorun.inf ,//setup.exe,// grass.ico,
> > > > > > > > oldCygwinGRASS-0.2.1_install.pdf, repository, //,
> > > > > > Handbücher.// On
> > > > > > > > loading the CD on CDROM drive, the installation
> > > > process should
> > > > > > > > start automatically.
> > > > > > > > With the help of CygwinGRASS-0.2.2_install.pdf manual i
> > > > > > carried out
> > > > > > > > the installation./
> > > > > > > > Regards
> > > > > > > > Nagesh
> > > > > > > > María Piquer Rodríguez wrote:
> > > > > > > > > Hello,
> > > > > > > > > When installing GRASS for Windows with cygwin , at the
> > > > > > step select
> > > > > > > > > your internet connection: as Direct connection (as
> > > > > > > > especified in the
> > > > > > > > > point 2 of the manual
> > http://geni.ath.cx/grass.html#toc6)
> > > > > > > > > I get the
> > > > > > > > > error: Can't get the list of download sites. Make sure
> > > > > > > > > your network settings are correct and try again.
> > > > > > > > > Can anyone explain me what to do now...? should I
> > > > > > select another
> > > > > > > > > internet connection?
> > > > > > > > > Thanks, thanks, thanks
> > > > > > > > > María
> > > > > > > > >> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> > > > > > > > >> To: 'María Piquer Rodríguez ' <almecloud at hotmail.com>,
> > > > > > > > >> "'grassuser at grass.itc.it '" <grassuser at grass.itc.it>
> > > > > > > > >> Subject: RE: [GRASS-user] Can't start GRASS 6.0.0
> > > > > > > > >> Date: Tue, 11 Jul 2006 10:58:23 -0300
> > > > > > > > >> Just out of curiosity, how did you install Grass 6.0? I
> > > > > > > > would think
> > > > > > > > >> that you would also need superuser privileges to
> > > > install 6.0.
> > > > > > > > >> ~ Eric.
> > > > > > > > >> -----Original Message-----
> > > > > > > > >> From: grassuser-bounces at grass.itc.it
> > > > > > > > >> To: grassuser at grass.itc.it
> > > > > > > > >> Sent: 7/11/2006 4:44 AM
> > > > > > > > >> Subject: [GRASS-user] Can't start GRASS 6.0.0
> > > > > > > > >> Hello, as a new user... I guess I am getting the common
> > > > > > > > problems... I
> > > > > > > > >> intalled GRASS 6.0 because were I work I cannot intall
> > > > > > > > >> 6.1
> > > > > > > > ( I cannot
> > > > > > > > >> unzip the files of the 6.1) as I am not the complete
> > > > > > > > administrator of
> > > > > > > > >> my computer.
> > > > > > > > >> I started to try with the shearfish data and when I
> > > > > > try to ENTER
> > > > > > > > >> GRASS it does not start... I get the following error:
> > > > > > > > >> GRASS 6.0.0 (shearfish60):~>Error un start up script :
> > > > > > > > child process
> > > > > > > > >> exited abno rmally when executing ...
> > > > > > > > >> I tried several times and I also tried to start it by
> > > > > > using the
> > > > > > > > >> command "d.m & ", a screen (with a detail of a
> > map) shows
> > > > > > > > up Loading
> > > > > > > > >> data, it says Done but I get the same error again...
> > > > > > > > >> Can anyone advice me what to do? Thanks
> > > > > > > > >> María Piquer
> > ________________________________________________________________
> > > > > > _
> > > > > > > > >> Un amor, una aventura, compañía para un viaje.
> > Regístrate
> > > > > > > > gratis en
> > > > > > > > >> MSN Amor & Amistad.
> > > > > > > > >> http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
> > > > > > > > >> grassuser mailing list
> > > > > > > > >> http://grass.itc.it/mailman/listinfo/grassuser
> > > > > > _
> > > > > > Regístrate gratis
> > > > > > > > > en MSN Amor & Amistad.
> > > > > > _ Un amor, una aventura, compañía para un viaje. Regístrate
> > > > gratis en
> > > > > > MSN Amor & Amistad.
> > > > _________________________________________________________________
> > > > Dale rienda suelta a tu tiempo libre. Mil ideas para exprimir tu
> > > > ocio con MSN Entretenimiento. http://entretenimiento.msn.es/
> > tu ocio con MSN Entretenimiento. http://entretenimiento.msn.es/
Descarga gratis la Barra de Herramientas de MSN
http://www.msn.es/usuario/busqueda/barra?XAPID=2031&DI=1055&SU=http%3A//www.hotmail.com&HL=LINKTAG1OPENINGTEXT_MSNBH
