[GRASS-user] v.in.ascii error message
Markus Neteler neteler at itc.it
Fri Jul 14 09:12:53 EDT 2006
On Thu, Jul 13, 2006 at 01:30:43AM -0700, gary wrote:
> I find this error message from v.in.ascii a bit cryptic.
> grass command:
> v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
> format=point fs=| skip=0 x=1 y=2 z=0 cat=0
> error message:
> Maximum input row length: 24
> Maximum number of columns: 2
> Minimum number of columns: 0
> GRASS_INFO_ERROR(15897,1): x column number > minimum last column number
> GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
> The file site. dat is one line as follows
> W115 58 2.4|N36 27 20.9
> The default separator is "pipe", so I'm sure the delimiter is fine. Any
> idea what I'm doing wrong here?
I guess that formatting should be
115:58:2.4W|36:27:20.9N
instead of
Markus
