[GRASS-user] v.in.ascii error message
Stuart Edwards sedwards2 at cinci.rr.com
Sat Jul 15 10:49:12 EDT 2006
Hi
This command has provided hours or entertainment for me too.  Usually
I can get it to work by meticulously following the format in example
1 on the help page.  To this end you might try making the W and N
into column headers, decimalize the lat/long and 'note the blank
before entering vertex coordinates'.  Adding a columns= string helps
too.  (columns='x double, etc).  Good luck.
Stuart
On Jul 14, 2006, at 4:07 PM, gary wrote:
> I changed the input format but got the same cryptic error message.
> Markus Neteler wrote:
>> On Thu, Jul 13, 2006 at 01:30:43AM -0700, gary wrote:
>>> I find this error message from v.in.ascii a bit cryptic.
>>> grass command:
>>> v.in.ascii input=/usr/localsrc/utm/PERMANENT/site.dat output=sites5
>>> format=point fs=| skip=0 x=1 y=2 z=0 cat=0
>>> error message:
>>> Maximum input row length: 24
>>> Maximum number of columns: 2
>>> Minimum number of columns: 0
>>> GRASS_INFO_ERROR(15897,1): x column number > minimum last column
>>> number
>>> GRASS_INFO_ERROR(15897,1): (incorrect field separator?)
>>> The file site. dat is one line as follows
>>> W115 58 2.4|N36 27 20.9
>>> The default separator is "pipe", so I'm sure the delimiter is
>>> fine. Any idea what I'm doing wrong here?
>> I guess that formatting should be
>> 115:58:2.4W|36:27:20.9N
>> instead of
>> Markus
>> grassuser mailing list
>> grassuser at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grassuser
