[GRASS-user] r.plane raster display problem
Maciej Sieczka
tutey at o2.pl
Sat Jul 15 13:04:38 EDT 2006
Maciej Tomaszczyk napisaĆ(a):
> i created some raster using r.plane
> but i am not able to display it, got error:
> WARNING: can't get history information for [myplane45] in mapset [troll]
> while executing
> "close $rt"
> (procedure "DmRaster::display" line 27)
> invoked from within
> "DmRaster::display $node"
> ("raster" arm line 2)
> invoked from within
> "switch $type {
> group {
> DmGroup::display $node
> raster {
> labels {
> DmLabels::display $node
> (procedure "Dm::display_node" line 6)
> invoked from within
> "Dm::display_node $n"
> (procedure "DmGroup::display" line 11)
> invoked from within
> "DmGroup::display "root" "
> (procedure "Dm::display" line 8)
> invoked from within
> "Dm::display"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
> (command bound to event)
> when i use r.out.gdal to export and use r.in.gdal to import this raster again to grass, raster dispalys with any problems
> i have grass6.1-cvs on my machine
> anyone know how to solve this???
I confirm - d.m and gis.m (current CVS) fail to display r.plane output
and they issue the above warning. d.rast works ok though.
I noticed that the history file created by r.plane is shorter than
minimum 8 lines I observed so far in case of other raster modules - only
5 lines. As an effect, r.info fails to report any history.
Maciej,
A workaround is to use r.support and answer "y" to "Edit the history
file for [map1]? (y/n) [n]", then ESC+ENTER twice and ENTER. Or to edit
the history file manually adding 4 empty lines.
Thanl's for letting now. Please fill a bug report about that. I'm not
sure if it is d.m/gis.m fault (being to strict about history missing) or
r.plane (that fails to create a valid history file). I guess that both
behave wrong here.
Maciek
