[GRASS-user] [GRASSLIST:1156] v.digit: Segmentation fault
H.S.Rai
hardeep.rai at gmail.com
Mon Jul 17 03:37:55 EDT 2006
Maciej Sieczka <tutey at o2.pl> wrote:
>Hardeep Singh Rai napisa?(a):
>> On GRASS6.0.2 on debian, v.digit is giving segmentation fault. Listing
>> is given below. What is wrong?
> Can you reproduce this with any vector, or only this one?
With all vectors, rather on two different machines, both running Debian.
May be same setup in all respect :-(
> What does "v.info v3" say?
cannot open old vector v3 at hsrai on level 2
> If you run "v.build v3", then v.digit - does that help?
v.build correct above mentioned problem. But on v.digit, it gave
"segmentaion fault" and on v.info again give same error of "cannot open
old vector v3 at hsrai on level 2".
> P.S. Quit using grasslist at baylor.edu. It is deprecated.
Thanks for correcting me.
H.S.Rai
