[GRASS-user] r.plane raster display problem
Hamish
hamish_nospam at yahoo.com
Mon Jul 17 20:09:38 EDT 2006
> >>>> Looking at scripts/r.plane/r.plane shows that an undesired
> >>>> method of generating the history is used. This must be
> >>>> changed. Apparently it is a bug in r.plane and not in
> >>>> the d.m/gis.m managers.
> >>> Fixed in CVS for both 6.1-HEAD and 6.1.0-Branch (for beta2 or
> >>> RC1). I have substituted the broken hist file creation by
> >>> r.support calls.
> >>> I quickly tried in d.m and it works now.
> >> Thanks for fixing this. The question remains why gis.m/d.m fails to
> >> display history-less a rasters while d.rast displays them fine?
Hamish:
> > see my message on the devel list 7-10 days ago about the same kind
> > of errors if the raster's cats/ file is missing, but if drawn with
> > d.rast it displays without complaint. I don't think it is
> > necessarily a bug for the software to complain when it comes across
> > a broken map, but it would be nice to understand why it acts
> > differently.
Michael:
> Yea. That's weird. Is it a d.rgb thing? If there is a drape map, the
> GUI switches from d.rast to d.rgb.
in spearfish: (or wherever)
r.mapcalc test1=1
d.mon x0
d.rast test1
[ok]
gis.m: display raster
[ok]
cd $MAPSET/
mv hist/test1 hist/test1.old
d.redraw
[ok]
gis.m: redraw
Error: WARNING: can't get history information for [test1] in mapset
[user1]
[Detail:]
WARNING: can't get history information for [test1] in mapset [user1]
while executing
"close $rt"
(procedure "GmRaster::display" line 40)
invoked from within
"GmRaster::display $node $mod"
("raster" arm line 2)
invoked from within
"switch $type {
group {
GmGroup::display $node $mod
raster {
labels {
GmLabels::disp..."
(procedure "GmTree::display_node" line 7)
invoked from within
"GmTree::display_node $n $mod"
(procedure "GmGroup::display" line 25)
invoked from within
"GmGroup::display "root" $mod"
(procedure "MapCanvas::runprograms" line 30)
invoked from within
"MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
(procedure "MapCanvas::drawmap" line 43)
invoked from within
"MapCanvas::drawmap $mon"
(procedure "MapCanvas::display_server" line 9)
invoked from within
("after" script)
then if gets stuck with "please wait.." at the bottom of the Map Display
1 window.
if you move away the cats/ file you get:
WARNING: category support for [test1] in mapset [user1] missing
while executing
"close $rt"
invoked from within
Hamish
