[GRASS-user] [GRASSLIST:1160] RE: Surface area of a DEM
Carlos "Guâno" Grohmann carlos.grohmann at gmail.com
Thu Jul 20 13:24:10 EDT 2006
Jonathan,
You can do that with r.mapcalc.
Calculations can be made with r.mapcalc, using the following formula
for a 50m regular grid:
50*(sqrt((exp((tan(A)*50), 2)) + 2500))
Where A is the slope map.
from: GROHMANN, C.H. 2004. Morphometric analysis in Geographic
Information Systems: applications of free software GRASS and R.
Computers & Geosciences, 30 (9-10):1055-1067.
cheers
Carlos Grohmann
On 7/20/06, Hamish <hamish_nospam at yahoo.com> wrote:
> Jonathan Greenberg wrote:
> > I was thinking this, but does the fact that a DEM grid cell is square
> > cause complications in this formulation?  A 45 degree slope to the
> > west would have a different surface area than a 45 degree slope to the
> > southwest.  I've come across some solutions that use a set of 8
> > triangles created by the lines between the center cell and each of its
> > 8 neighbors to help in the calculation, but I was hoping this ability
> > might be buried in a GRASS command someplace.
> think of each cell as a spinning dinner plate on a stick.
> you can rotate each cell in the direction of the aspect, and the
> slope->projected area will be the same.
> dx*dy is its own entity, or if you prefer, the r.mapcalc command doesn't
> know about the aspect.
> Hamish
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc  - Doctorate Student at IGc-USP - Brazil
Linux User #89721  - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
