[GRASS-user] Importing e00 and running m.in.e00
Alexandre Leroux alexandre.leroux at ec.gc.ca
Fri Jul 21 10:01:22 EDT 2006
Thanks Hamish :-)
Is there a reason why the AVCE00 library, required to run v.in.e00, is
not installed by default with GRASS (6.0.2)?
Is there a reason why this v.in.e00 is not present in the
File\Import\Raster map\ menu?
Have a nice day :-)
Alex
Hamish wrote:
> Alexandre Leroux wrote:
>> I need import e00 files using Grass 6.0.2. When I look at the importing
>> raster menu, I find nothing. Searching on the Internet made me aware of
>> m.in.e00 (http://grass.itc.it/gdp/html_grass5/html/m.in.e00.html ) but
>> when I try to run it from the command tool, I get this not found error
>> "GRASS-GRID > m.in.e00   /bin/ksh: m.in.e00: not found".
>> GDAL does not support e00 files (http://gdal.org/formats_list.html).
>> I wanted to solve this simple issue myself and I'm sure this topic was
>> discussed on many occasions, but I haven't found a way to search the
>> list's archive (http://grass.itc.it/pipermail/grassuser/). I also took a
>> look at the GRASS wiki without any luck.
> v.in.e00
> http://grass.ibiblio.org/grass61/manuals/html61_user/v.in.e00.html
> Hamish
Alexandre Leroux, M.Sc., Ing.
Environnement Canada / Environment Canada
Centre météorologique canadien / Canadian Meteorological Centre
Division de la réponse aux urgences environnementales /
Environmental Emergency Response Division
