[GRASS-user] Contour lines extraction
Odoardo Zecca
odoardo.zecca at gmail.com
Fri Jul 21 10:23:41 EDT 2006
On 7/21/06, Odoardo Zecca <odoardo.zecca at gmail.com> wrote:
> Thank you Maciej.
> It seem to work only for points, but not for lines. Maybe this doesn't
> work for lines because they don't have a unique x and y but only a unique z,
> or am I doing something wrong?
OK! the right option is 'start' (or 'end'):
v.db.addcol map=cl6361 layer=1 "columns=x double precision,y double
precision,z double precision"
v.to.db map=cl6361 type=line layer=1 qlayer=1 units=meters option=start
column=x,y,z
Thank you very much, Maciej, this is an important step for may work!
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060721/ac4b97b4/attachment.html
