[GRASS-user] Combining Rasters Help
Fri Jul 21 19:38:58 EDT 2006
Markus Neteler wrote:
> > You need to recompile to change the upper limit; both libgis and
> > r.patch have their own limits. Even if you do that, 4400 open files
> > may exceed limits imposed by the OS.
> Curiosity:
> Would it makes sense to unify these different limits into
> a single one (gis.h or so)? Also xganim is affected and others.
> From a user perspective it would be less confusing.
It would be better to just do away with the limits, i.e. change
G__.fileinfo from an array to a pointer and dynamically re-allocate it
as necessary. Similarly for individual modules.
