[GRASS-user] Running problems
María Piquer Rodríguez almecloud at hotmail.com
Mon Jul 24 10:11:07 EDT 2006
I had the same experience as you. I tried to run GRASS 6.0 on Windows
environment with Cygwin and I got the same error, after 4 days of trying
different things, the easiest was to install the 6.1 version. Everthing
worked perfeclty!!
Good luck!
María
>From: Jachym Cepicky <jachym.cepicky at centrum.cz>
>To: jur ven <jurven007 at yahoo.com>
>CC: grassuser at grass.itc.it
>Subject: Re: [GRASS-user] Running problems
>Date: Wed, 19 Jul 2006 16:56:23 +0200
>Hi
>first of all, you should metion, that you are running GRASS on windows
>using cygwin.
>I allways used the 6.1 version on cygwin, it worked well. 6.0. is
>becoming to be little bit outdated. After installing the 6.1 package,
>version 6.0 should work too
>jachym
>On Wed, Jul 19, 2006 at 06:45:35AM -0700, jur ven wrote:
> > Hi All,
> > I decided to try this program and downloaded the 6.0
> > version. I installed everything with success and were
> > able to run the data selection. Afterwards I
> > downloaded spearfish and unpacked it in the
> > home/<username>/datbase folder. I was able to select
> > the neccesary folders but when I press start grass,
> > the progra stops....
> > In the DOS window I received the following data:
> > Welcome to GRASS 6.0.0 (2005)
> > GRASS homepage:
> > http://grass.itc.it/
> > This version running thru:               GNU Bash
> > (Cygwin) (/usr/bin/bash.exe)
> > Help is available with the command:      g.manual -i
> > See the licence terms with:              g.version -c
> > If required, restart the graphical user interface
> > with: d.m &
> > When ready to quit enter:                exit
> > GRASS 6.0.0 (spearfish57):~ > Error in startup script:
> > child process exited abnormally
> >     while executing
> > "exec ps.map -p"
> >     (procedure "DmPrint::init" line 14)
> >     invoked from within
> > "DmPrint::init"
> >     (procedure "main" line 32)
> >     invoked from within
> > "main $argc $argv"
> >     (file "/usr/local/grass6.0.0/etc/dm/d.m.tcl" line
> > 894)
> > Can someone please help me???
> > __________________________________________________
> > Do You Yahoo!?
> > Tired of spam?  Yahoo! Mail has the best spam protection around
> > http://mail.yahoo.com
> > grassuser mailing list
> > http://grass.itc.it/mailman/listinfo/grassuser
>Jachym Cepicky
>e-mail: jachym.cepicky at centrum.cz
>URL: http://les-ejk.cz
>GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
>OFFICE:
>GDF-Hannover
>Mengendamm 16d
>30177 Hannover
>Germany
>e-mail: cepicky at gdf-hannover.de
>URL:    http://gdf-hannover.de
>Tel.:   +49 511-39088507
><< signature.asc >>
_________________________________________________________________
Moda para esta temporada. Ponte al día de todas las tendencias.
http://www.msn.es/Mujer/moda/default.asp
