[GRASS-user] Problem with v.surf.rst
José A. Ruiz Arias jararias at ujaen.es
Wed Jul 26 08:31:26 EDT 2006
Hi list,
I am trying to get a raster map interpolating from a vector file with 14
nodes by means of v.surf.rst.  I use GRASS 6.0.0 (according to
g.version). The steps I made were the nexts:
1. Create a Grass 3D vector file from an ASCII file using v.in.ascii.
The ASCII file (named kc.dat) is
502130|4111284|0.75|1
502243|4111212|0.23|2
502532|4111109|0.54|3
502334|4111674|0.67|4
502639|4111461|0.34|5
502905|4111461|0.87|6
503062|4111460|0.42|7
503325|4111154|0.74|8
503111|4111107|0.67|9
503539|4112190|0.38|10
503828|4112280|0.46|11
503658|4112414|0.98|12
505529|4114325|0.67|13
508391|4116254|0.87|14
where the first two columns are the coords, the third is the z-value and the last one a cat column.
Using the command
> cat kc.dat | v.in.ascii -z z=3 cat=4 out=kctest columns='x double, y double, z double, cat int'
it seems there is no problem and the vector is created. Actually with v.info kctest I get the next info
> v.info kctest
 | Layer:    kctest                         Organization:                     |
 | Mapset:   joseantonio                    Source Date:                      |
 | Location: huenejaUTM100                  Name of creator:                  |
 | Database: /home/joseantonio/grassdata                                      |
 | Title:        |
 | Map Scale:  1:1                                                            |
 | Map format: native                                                         |
 |   Type of Map:  Vector (level: 2)                                          |
 |   Number of points:       14              Number of areas:      0          |
 |   Number of lines:        0               Number of islands:    0          |
 |   Number of boundaries:   0               Number of faces:      0          |
 |   Number of centroids:    0               Number of kernels:    0          |
 |   Map is 3D:              1                                                |
 |   Number of dblinks:      0                                                |
 |   Projection: UTM (zone 30)                                                |
 |            N: 4116254.000    S: 4111107.000                                |
 |            E: 508391.000     W: 502130.000                                 |
 |            B: 0.230         T: 0.980                                       |
 |   Digitize threshold: 0.00000                                              |
 |   Comments:        |
2. Set the region by means of
> g.region -p res=100
3. Interpolate with v.surf.rst getting the next error message:
> v.surf.rst input=kctest elev=kcsurface
Authors: original version -  H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
See manual pages for reference and publications T3
Percent complete: Loading data from attribute table ...
ERROR: Cannot get layer info
Someone knows where the problem is?
Thanks in advance,
José A. Ruiz
Departament of Physics
University of Jaen
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060726/c12d3776/attachment.html
