[GRASS-user] r.cva -f option: "calculate the visibility from rather than viewsheds of"; English translation requested ; -)
Mark Lake mark.lake at ucl.ac.uk
Thu Jul 27 04:54:40 EDT 2006
Gary,
> Would someone elaborate on the difference between "visibility from"
> and "viewshed of".
As the original author of r.cva I have to admit that the choice of
terminology could perhaps have been clearer, but this choice is
explained in the man page if you have that on your system.  Also
check  the info. at http://www.ucl.ac.uk/~tcrnmar/GIS/r.cva.html
Normally, i.e. without choosing the -f flag / NOT checking the
"Calculate visibility from ..." box, r.cva produces output in which
each non-NULL cell represents a viewpoint and contains a count of the
number of cells visible from that viewpoint.  Thus if you specify
just one viewpoint, you should get output containing one cell
effectively recording the size (in number of cells) of the viewshed
of that viewpoint.
If you do set the -f flag / check the "Calcuclate visibility
from ..." box, then r.cva produces rather different output in which
each non-NULL cell represents a cell which is visible from one or
more viewpoints and contains a count of the number of viewpoints from
which it is visible.  Thus if you specify just one viewpoint, you
should get output that is essentially the same as converting the
output from r.los into binary form (i.e. you get a traditional
viewshed map showing what area is visible from the selected viewpoint).
You can further change exactly what is being calculated by reversing
the observer and target offsets.  This is because the fact that you
can see A from B does not guarantee that you can see B from A, unless
the height of the observer is equal to any target offset that may
have been set.
These issues have been widely discussed in the archaeological
literature.  If you have access to a library you should look at:
Conolly, J. and Lake, M. (2006).
           Geographical Information Systems in Archaeology.
           Cambridge Manuals in Archaeology. Cambridge University Press,
           Cambridge.
           Pages 225-233
Wheatley, D. and Gillings, M. (2002).
           Spatial Technology and Archaeology: The Archaeological
           Applications of GIS.
           Taylor & Francis, New York.
           Pages 201-214
Directly related methodological issues are also discussed in:
Fisher, P. F., Farrelly, C., Maddocks, A., and Ruggles, C. (1997).
           Spatial analysis of visible areas from the Bronze Age
cairns of
           Mull.
           Journal of Archaeological Science, 24:581-592.
Lake, M. W., Woodman, P. E., and Mithen, S. J. (1998).
           Tailoring GIS software for archaeological applications: An
           example concerning viewshed analysis.
           Journal of Archaeological Science, 25:27-38.
I'm out of contact now for 10 days, so won't be able to answer
further questions until after that.
Mark
Dr Mark Lake
Institute of Archaeology
University College London
31-34 Gordon Square
London.  WC1H 0PY
Tel: +44 (0)207 679 7495
Fax: +44 (0)207 383 2572
