[GRASS-user] how to add categories to vector created with r.t o.vect
Patton, Eric epatton at nrcan.gc.ca
Thu Jul 27 11:21:39 EDT 2006
Jarek,
Have you had a look at v.category?
http://grass.itc.it/grass61/manuals/html61_user/v.category.html
You can add category sequentially to all of your lines.
~ Eric.
-----Original Message-----
To: grassuser at grass.itc.it
Sent: 7/27/2006 11:08 AM
Subject: [GRASS-user] how to add categories to vector created with r.to.vect
I created the vector file (lines) with  r.to.vect
In help I red that NO CATEGORIES for lines are created (I understood -
the obiect hasn't identifier). I need to work on data base with them so
I need give them a cat values
The manual entry is not an option because there is over 32000 lines
any ideas?
I can't still use PostGIS due to problems with installation (if somebody
will sugest it)
Jarek
grassuser mailing list
http://grass.itc.it/mailman/listinfo/grassuser
