[GRASS-user] problem to import E00 file
Raymond Fu raymond_fu at yahoo.com
Mon Jul 31 04:47:34 EDT 2006
yes. it is latest 6.1 version.   I have installed v.in.e00 into the application, but deson't work as the screen dump.   It is ok when I run the v.in.e00 separately(i.e. the coverage can be generated.
  Thanks
  Raymond
M S <mseibel at gmail.com> wrote:
  is that new for 6.1? i dont recall using those utilities to import an e00.
you cant just import with v.in.e00?
not sure, but how about the data feature type.  is the right one being chosen (ie. point, line polygon?)
  On 7/28/06, Moritz Lennert < mlennert at club.worldonline.be> wrote:  Raymond Fu wrote:
>     hi,
>     did anyone has the similar problem before?
Yes, I have:
http://lists.alioth.debian.org/pipermail/pkg-grass-general/2005-February/000630.html
Are you sure your file is a vector file ?
Moritz
>     I am trying to import E00 file in GRASS GIS Version 6.1 cvs.  The
>     application asked me to download the avcimport and E00Convert from
>     http://avce00.maptools.org/.   I copied the avcimport.exe
>     e00conv.exe to cygwin\bin.  However, during import, the error
>     "Cannot open data source: bldg An error occurred. Stop." was still
>     prompted out as attached.   Do you have any idea, how can the
>     problem be solved?
>     Thanks in advance.
>     Raymond
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060731/86130633/attachment.html
